PeterFukt Posted January 24, 2017 Report Share Posted January 24, 2017 Hi, I made many changes in a program today and created a project file for the customer to download it with Unidownloader. But after I saved it, I noticed that the project file saved itself with the same filename as the original program, including the .vlp format. So now I have a project file but no Visilogic program file. Is there anyway I can get the program back using the .vdf file or is the program code including half a day of work lost? Quote Link to comment Share on other sites More sharing options...
Ofir Posted February 5, 2017 Report Share Posted February 5, 2017 Hi, You can try the following: Open UniDowload Designer Link the VDF file. Select the checkbox "Download data for Upload" Create UDC and download it to the PLC using UniDownloader Then using VisiLogic select to upload the project. Quote Link to comment Share on other sites More sharing options...
