kurtv Posted February 19, 2011 Report Share Posted February 19, 2011 Hi I use a M91-2-T38 can i write data to excell? With data export? I have only 1 port rs 232/rs485. This port is for download the program to the plc but can i use the port to connect to pc? Data export? And how can i make the cabel? Thanks Regards Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted February 20, 2011 Report Share Posted February 20, 2011 Hi, The serial port is used for all communcation between VisiLogic and the PLC. Use the Data Xport program to retrieve data from the PLC and to transfer the Data Base into Excel. Quote Link to comment Share on other sites More sharing options...
kurtv Posted February 23, 2011 Author Report Share Posted February 23, 2011 Hi But the question is can i make communication witch the opc server and citect witch the model that i use ? I have only 1 port that i use to load the program into the plc. Is it possible? The model is M91-2-T38 Thanks Regards Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted February 24, 2011 Report Share Posted February 24, 2011 The answer is yes. The port is in use while downloading applications and while in online mode. In the rest of the time it can be used by other software, such as DataXport. Quote Link to comment Share on other sites More sharing options...
kurtv Posted February 24, 2011 Author Report Share Posted February 24, 2011 Thanks I try to fix it Regards Quote Link to comment Share on other sites More sharing options...
