MVP 2023 Ausman Posted February 7, 2017 MVP 2023 Report Share Posted February 7, 2017 Hi all, something not quite right in the comms dropdown box. I recently moved up to 9.8.31/0 and all seems ok but the dropdown functions oddly. The characters become much larger during selection, and I can also edit them. I thought this might have been a fix of something I requested a while back, but the edit doesn't persist. Also, sometimes I can only get Direct Connection showing, the drop down doesn't work at all. The only thing I have as a pointer is that it seems to be related to opening something new, or opening after not finding a file where it used to be. You close and restart and the issue goes away. And an edit: I initially attached .bmps to this post, but they don't display as part of the post...just a link. Changed them to jpgs and they do. ?? cheers, Aus 1 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted February 7, 2017 MVP 2023 Report Share Posted February 7, 2017 I rarely use the comms dropdown box, but I just checked and I see the same problem as Ausman. I am also still seeing the Modem box pop up randomly when I try to connect to the PLC over serial connection. When that happens the connection is dropped and cannot be restarted. FYI, this is using VisiLogic 9.8.31 and Windows 7 - 64-bit. 1 Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted February 20, 2017 Report Share Posted February 20, 2017 Thanks! We will look into it Quote Link to comment Share on other sites More sharing options...
