Jon1711 Posted February 9, 2017 Report Share Posted February 9, 2017 Hi All, Is there any way to delete multiple files from the SD Card using the in built SD Browser? Thanks in advance, Jon Quote Link to comment Share on other sites More sharing options...
Cam Posted February 9, 2017 Report Share Posted February 9, 2017 Hi Jon, No via the browse SD card function you can only delete 1 file at a time. If you can use a PC and connect to the PLC via the SD explorer software which is part of the SD Card Suite you can then select and delete multiple files at a time. Cam 2 Quote Link to comment Share on other sites More sharing options...
Jon1711 Posted February 9, 2017 Author Report Share Posted February 9, 2017 Ah right ok, thank you for your reply! Quote Link to comment Share on other sites More sharing options...
