Jose Ruben Castro Ramirez Posted February 9, 2017 Report Share Posted February 9, 2017 I need help convert the analog signal from 4 to 20 m from a gpm to l / m flowmeter in a plc jazz Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted February 9, 2017 MVP 2023 Report Share Posted February 9, 2017 There is a linearization function in the U90 Ladder, but it can be a bit confusing. Be sure to read the Help file carefully and you should be able to do it. If not, we'll try to help. Quote Link to comment Share on other sites More sharing options...
