  • MVP 2023
I'd also look at using a TE timer, which will do it in one hit.  But either way, you also need to be setting up a differential around the trigger point, otherwise it will endlessly cycle the alarm as your levels go up and down around trigger point.  Sometimes you DO need to over complicate things.  One must remember that your student is the dumbest of dumb, yet very obedient.  It will always do only what you tell it to.........endlessly! You have to do the thinking for it.
On Timers, if you haven't used them much yet, have a good read of the help files via Index/Timers.  Explains well.  Ages ago I took a while to get my head around the way Unitronics do them, making them via using Direct Coil was new to me.  Also that they only have 3 types.
cheers,
Aus
  • Upvote 1
  • 2 weeks later...
I have to thank Joe Tauser for that. He did an LOT of QA on those timer diagrams.
