TiTo Posted February 21, 2011 Report Share Posted February 21, 2011 Hello! Sorry my english is bad . I need help. can i connect to Unitronics under Linux. Quote Link to comment Share on other sites More sharing options...
Ofir Posted February 22, 2011 Report Share Posted February 22, 2011 Hi Tito, Unitronics software does not run under Linux/Unix. Quote Link to comment Share on other sites More sharing options...
External Moderators Ash Neilson Posted February 22, 2011 External Moderators Report Share Posted February 22, 2011 Hi Tito, I created a MONO .NET version of the Unitronics Communication Driver back in 2008. It became out-dated and un-used so it was forgotten about. I am planning on creating a new version of the MONO .Net Communication Driver in the next month or two. When are you hoping you could use this Library? Quote Link to comment Share on other sites More sharing options...
TiTo Posted February 24, 2011 Author Report Share Posted February 24, 2011 Hi Tito, I created a MONO .NET version of the Unitronics Communication Driver back in 2008. It became out-dated and un-used so it was forgotten about. I am planning on creating a new version of the MONO .Net Communication Driver in the next month or two. When are you hoping you could use this Library? I'm hoping I could use this Library in aprile. Thanks for your reply Quote Link to comment Share on other sites More sharing options...
Lionel Posted June 30, 2011 Report Share Posted June 30, 2011 Hi Ash, Did you released your Mono .net driver ? Best regards, Quote Link to comment Share on other sites More sharing options...
External Moderators Ash Neilson Posted July 4, 2011 External Moderators Report Share Posted July 4, 2011 Hi Lionel, I haven't yet had the chance to sit down and finalize a MONO .NET Library for Unitronics. I do have something in progress, however, I need to complete it and bug test before releasing. I'll try and keep you informed by posting any updates here. Quote Link to comment Share on other sites More sharing options...
jhfrontz Posted March 12, 2013 Report Share Posted March 12, 2013 Any news? Would it be possible to post the source to the legacy software somewhere so that we could use it as a model for developing something custom? Quote Link to comment Share on other sites More sharing options...
External Moderators Ash Neilson Posted March 13, 2013 External Moderators Report Share Posted March 13, 2013 You can find a Download for the Unitronics.ComDriver Source Code (C#) here: http://www.unitronics.com/Data/Uploads/software%20utilities/Unitronics.ComDrive.SourceCodes_Ver_1.0.0.47.zip This should allow you to support your platform. Quote Link to comment Share on other sites More sharing options...
peteykirk Posted May 15, 2013 Report Share Posted May 15, 2013 The link for this no longer works, did the new one get finished or can the old one be uploaded again? Quote Link to comment Share on other sites More sharing options...
Saragani Posted May 16, 2013 Report Share Posted May 16, 2013 Hi, the Linux communication driver was based on Mono. The Mono project is sponsored by Xamarin and from knowing the capabilities of the ".net" framework of Xamarin for Android (And I assume it is the same for iOS as well), the communication driver can be 100% or at least 99% be converted to Mono. Parts that will probably won't work are the Logger (that works with .mdb files), but if you don't need it then just remove it. You have the .Net driver sources on the website. Just do it yourself.... Quote Link to comment Share on other sites More sharing options...
