SERTAN Posted February 24, 2017 Report Share Posted February 24, 2017 Hi i want to connect vision V1040 to Uniformance PHD by using uni opc. but can't do that. when i start uniopc, i see on error window runtime error 70 permission denied. i want to try by kepserverex, can you explain me how can i configure kepserverex and plc side? Best regards. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted February 28, 2017 MVP 2023 Report Share Posted February 28, 2017 Do you have the properties of UniOPC set to "Run as Administrator"? Joe T. Quote Link to comment Share on other sites More sharing options...
SERTAN Posted February 28, 2017 Author Report Share Posted February 28, 2017 (edited) Yes. UniOPC set to "Run as Administrator" but it doesn't work with honeywell UNIFORMANCE PHD SERVER. I don't want use UniOPC, I want to use kepserverex, because kepserverex already runing with honeywell UNIFORMANCE PHD SERVER. can you explain me how can i configure kepserverex and unitronics plc side? Best regards. Edited February 28, 2017 by SERTAN edit Quote Link to comment Share on other sites More sharing options...
