steve_mac Posted February 28, 2017 Report Share Posted February 28, 2017 Dear Friends, In dryer I changed CMOS battery... After that it working normally.I can set my values as like before replacing CMOS battery... When I start the machine I can't see thee temperature on display.It simply showing ****.****like How to solve this problem..? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted February 28, 2017 MVP 2023 Report Share Posted February 28, 2017 The asterisks normally indicate a value that is out of range for its display properties. You need to examine that operand (either in Info Mode or Online with VisiLogic) to see what its actual value is and then work your way back to determine why it's out of range. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted March 1, 2017 MVP 2023 Report Share Posted March 1, 2017 I'd also be carefully checking that you have refitted all connections correctly during the battery replacement process. Plugs fully into sockets etc. Or perhaps have broken a wire without it being obvious? If the temp is highly averaged, it might take a while to come back to normal. But in this case I doubt it. cheers, Aus Quote Link to comment Share on other sites More sharing options...
