tonymony Posted February 28, 2017 Report Share Posted February 28, 2017 Hello, I am currently working in a project with expansion modules IO-DI8-TO8/RO8. All my expansion is full I have 8, could I change one of the IO-DI8-TO8/RO8 for one IO-DI16 to increase the inputs number? Thanks, Quote Link to comment Share on other sites More sharing options...
Ofir Posted February 28, 2017 Report Share Posted February 28, 2017 Hi, First of all if you replace the IO-DI8-TO8/RO8 to IO-DI16 ,you will not have outputs. If you are not using it then you will need to remove this module in the hardware configuration and add the new one. BTW if you do need the outputs you can use the IO-DI16A3-TO16 Quote Link to comment Share on other sites More sharing options...
