Paul J Posted March 7, 2017 Report Share Posted March 7, 2017 Hi I am trying to connect to a scada network on a V570 using Modbus IP. No success so far. I have attached a screen cap of my ethernet startup (couldnt get it to paste direct). Could someone please have a look and see what I have done wrong. Thanks Paul J V570 Modbus.pptx Quote Link to comment Share on other sites More sharing options...
AlexUT Posted March 7, 2017 Report Share Posted March 7, 2017 Hi Paul J, Use next example for MODBUS TCP Slave: C:\Program Files (x86)\Unitronics\Unitronics VisiLogic_C\Examples\Version 900\Project examples\Communications\Ethernet\Ethernet MODBUS IP\V280_Ethernet_TCP_MODBUS_IP_Slave.vlp This example include all required functions. Quote Link to comment Share on other sites More sharing options...
Paul J Posted March 7, 2017 Author Report Share Posted March 7, 2017 Thanks For reply, this is the example I used.The only difference is I am using a different IP address and gateway address. Modbus scan bit is showing true. Do you think this may be Scada related problem. Regards Quote Link to comment Share on other sites More sharing options...
AlexUT Posted March 7, 2017 Report Share Posted March 7, 2017 Hi Paul J, Tell me your PLC IP address (send it to support@unitronics.com) and I will check connection by Modbus application. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted March 7, 2017 Report Share Posted March 7, 2017 Hi Paul J, IP address you use is from private address space. It is not accessible direct from the Internet. It can be accessible only from the same network. If this IP address after router, you have to make port forwarding at router to access this PLC from Internet. B.R. Quote Link to comment Share on other sites More sharing options...
Paul J Posted March 7, 2017 Author Report Share Posted March 7, 2017 Thanks for reply You are correct this is to connect to a closed network for Scada application. It is to connect to OPC server. Quote Link to comment Share on other sites More sharing options...
