MVP 2023 Ausman Posted March 23, 2017 MVP 2023 Report Share Posted March 23, 2017 Hi again all, can the creators please explain what this .exe does and when, and why it sometimes persists after the program closes. It is not running as a service, appears to be initiated on start of Unilogic, sometimes starting a number of instances on the same port each opening (but different each time), and then perhaps retaining one after close. Behaviour doesn't seem to be consistent each time. cheers. Aus Quote Link to comment Share on other sites More sharing options...
