Declan Byrne Posted March 23, 2017 Report Share Posted March 23, 2017 Hi, Pretty simple question but for some reason as a beginner I am having trouble finding out. When using a snap-on IO and then an Expansion module and IO, how do I enter my inputs into my program after I have filled my snap-on IO Number wise? When the next IO starts at I0 does it matter what number the input isin the program in regards to hard wiring into the module? eg; I have room for 18 digital inputs, I am only using 14 on my snap-on IO, on my next IO I am using 13 of the 16 digital inputs, I will number my inputs in entered in my program 0-13 regards to how they are hard wired, i have On my next IO what number do I start on in my program considering my IO Starts at I0 in regards to my hard wired cables? I hope this makes sense. Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted March 23, 2017 MVP 2023 Report Share Posted March 23, 2017 Unitronics does not have flexible I/O addressing. Ignore what is printed on the module. When you configure your I/O in the Hardware Configuration dialog, it will tell you what the addresses will be on each module. I know this is confusing. There are little stickers included with each expansion module so you can re-label them as to what they really are. Joe T. Quote Link to comment Share on other sites More sharing options...
