7techno Posted April 14, 2017 Report Share Posted April 14, 2017 I have 3 Unistream panels and two EX-RC1 with 6-7 IO modules connected to each one. My question is how to configure each panel to collect data from/to both of EX-RC1. In Unilogic examples there is only one adapter and invariant starting address MI1016. In case with single EX-RC1 all is clear, but how to be with two adapters? It baffles me invariant starting address MI1016. Sorry for my English. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted April 16, 2017 MVP 2023 Report Share Posted April 16, 2017 You set the network ID of the RC1 with the dip switches, and each RC1 must have a Node ID. Make separate entries in the UniCAN table for each one. Do have have the start of a program you can post? Joe T. Quote Link to comment Share on other sites More sharing options...
7techno Posted April 17, 2017 Author Report Share Posted April 17, 2017 In the attached screenshots two RC1. I set ID 11 and 12. What should I do next? Should I copy this settings to other two panels without changing, with ID11 and ID12? In Visilogic program for each RC1 I`ll make three networks (for each panel) with Unican Send block different by cycle time for sending data. It`s correct solution? Quote Link to comment Share on other sites More sharing options...
NOVI Posted June 6, 2017 Report Share Posted June 6, 2017 correcting Quote Link to comment Share on other sites More sharing options...
NOVI Posted June 6, 2017 Report Share Posted June 6, 2017 Sorry I'll see where the i have mistake, but I will correct Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted June 7, 2017 Report Share Posted June 7, 2017 Do you expect having 3 Unistream panels acting as Masters of UniCAN network? I´m not sure it will be possible. Is it possible for you to use a single Unistream to communicate with both EX-RC1 and exchange data over Ethernet with another two Unistream? Quote Link to comment Share on other sites More sharing options...
NOVI Posted June 10, 2017 Report Share Posted June 10, 2017 EX-RC 1 Simply testing to help you and be do not waste valuable time All I checked on-line and measured D - IN & OUT, IN-mA, IN and OUT VOLTAGE and all functioning correctly. 2 X - IO-D16A3TO16 + IO-AO6X+IO-AI4-AO2 MASTER V 1040.vlp RC#2 ( SLAVE ).vlp RC#3 (slave ).vlp Quote Link to comment Share on other sites More sharing options...
LulaNord Posted June 21, 2017 Report Share Posted June 21, 2017 Hi...i am a new user here. I want to know do you expect having 3 Unistream panels acting as Masters of UniCAN network? I´m not sure it will be possible.Is it possible for you to use a single Unistream to communicate with both EX-RC1 and exchange data over Ethernet with another two Unistream? circuit assembly Quote Link to comment Share on other sites More sharing options...
NOVI Posted June 26, 2017 Report Share Posted June 26, 2017 On 6/21/2017 at 8:19 PM, LulaNord said: Hi...i am a new user here. I want to know do you expect having 3 Unistream panels acting as Masters of UniCAN network? I´m not sure it will be possible.Is it possible for you to use a single Unistream to communicate with both EX-RC1 and exchange data ove Ethernet with another two Unistream? Yes it's possible. The thing is just in correct addressing, One PLC must be master and he must communicate with RC 1. Use the app I made for testing, in all three PLCs just give them their addresses correctly and determine who will communicate with RC 1 I do not have free three PLC-s to try Quote Link to comment Share on other sites More sharing options...
