hassan Posted April 20, 2017 Report Share Posted April 20, 2017 I'm a student engineer and I'm working on my final graduating project, i have to make a specialized TIG welding machine for aeronautical use. what i'm asking is can i logg an analog input 0-10V into a data table and save it to reuse it as information for a analog output 0-10V many times after recording the data (i want to code the learning mode then a working mode ) thank you Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted April 20, 2017 MVP 2023 Report Share Posted April 20, 2017 Sure you can - easily. When you have the ladder displayed, look just above the ladder window and you'll find a drop down labeled "Data Tables". It has all the ladder commands you'll need to store, manipulate, and recall data from the data tables. You'll need to create your data table first with the properties you need for your application. Quote Link to comment Share on other sites More sharing options...
hassan Posted April 20, 2017 Author Report Share Posted April 20, 2017 thank you so much this would be awesome Quote Link to comment Share on other sites More sharing options...
