hotwires Posted May 7, 2017 Report Share Posted May 7, 2017 Will the future bring a drag and drop email body element that inserts an ASCII string variable? I've found a work around for what I'm wanting to accomplish via binary text variable and lists of text variable. What I had in my was using store blocks in ladder to load an ASCII string with various messages then IF triggered email would convey the ASCII string message in body. Just a thought. Not sure if anyone else has looked for this as a feature. I guess I got the notion from email construct strategy I once used in Visilogic using Stores, Strings, and string to vector block (admittedly more complicated). Quote Link to comment Share on other sites More sharing options...
Ofir Posted July 16, 2017 Report Share Posted July 16, 2017 There is way to send indirect text as body of a mail message . It requires some ladder logic. There is a function called append buffer to user file that appends a buffer to a TXT/CSV/BIN file. You can use copy tag to buffer first and then using the append buffer to file , you are basically creating a file with the tag data. (you can also use the message composer to create messages and then use Build message to put it in a buffer). This buffer is the one you will append to the user file. The file needs to be TXT. In the e-mail configuration you will click on attachment an select the file with the text you wish to send and then the option send as body. The file will not be as attachment but its content will be in the body of the mail. 1 Quote Link to comment Share on other sites More sharing options...
newbie88 Posted January 21, 2020 Report Share Posted January 21, 2020 Hi there, i only can find append buffer to SD file instead of user file. Is this the same? By the way visilogic can assign an indirect tags to the "from email", so can unilogic also able to assign an indirect tags account on hmi for user to define himself instead of using a fix one? Quote Link to comment Share on other sites More sharing options...
