Dornier Posted May 12, 2017 Report Share Posted May 12, 2017 Hello! I'm trying to configure CanOpen communication between Lenze ECSxP Posi&Shaft and Unitronics V1210. I want to set the velocity and the position using PDO1. If I give a high level to the fifteenth bit the control word becomes: First 15 bits are control bits (begin from 0) The velocity value is between 16 to 31 bits it means i can store the value using MI. The velocity is effected in the process data telegram in percent of maximum speed. And the position is between 32 to 61 bits. It is carried out in the process data telegram in resolver increments. I want to give values between 16 and 61 bits It is not possible to use MI to store the position value i need DW, however...inside CANopen Configuration block for RPDO Tx i can use only MI only ML or only DW. Could you give me suggestions how to solve the problem? Quote Link to comment Share on other sites More sharing options...
Ofir Posted May 15, 2017 Report Share Posted May 15, 2017 Hi, You can use Map register bytes. (You can find this element under CANopen menu). Using this element you can set a source vector of MIs and assign & map different operands types to this vector. Quote Link to comment Share on other sites More sharing options...
