SquarePLC Posted May 26, 2017 Report Share Posted May 26, 2017 Hi All, I'm wondering if anyone has used the UniStream to cue videos on a separate television monitor? I am hoping to create a few hot buttons on a screen that start videos on demand not sure if this is possible by using just the PLC or if I would need some type of interface. Any advice would be appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted May 26, 2017 MVP 2023 Report Share Posted May 26, 2017 If the video system has digital inputs available or communicates with a protocol compatible with the PLC, then it should be simple. Otherwise, it might be more difficult. 1 Quote Link to comment Share on other sites More sharing options...
