Juandiaza Posted June 1, 2017 Report Share Posted June 1, 2017 Hi, everyone I need some help to connect my incremental encoder 600 p/min 24 volts to my project I'd been trying to connect my encoder in order to read the pulses on my HMI but I don't know how I do that?????? I wire it up as the schematic. The encoder comes with 4 wires Red, Black, Green, and White. Red = Vcc = here I linked + 24 volts Black = 0 = here I linked 0 Volts Green = Phase A = I linked with Input terminal block (I 0 ) as show schematic PLC diagram White = Phase B = I linked with Input terminal block (I 1 ) as show schematic PLC diagram My question is If I want to see the pulses over the HMI. How Can I do that? I know that question might sound pretty easy but I tried with a (variable : numeric) over my HMI but the value doesn't increase or decrease. It keep in 0 Once I can see the value. I would like to make a curve graph to see over it. How to increase and decrease those values. Thanks Quote Link to comment Share on other sites More sharing options...
DanT Posted June 2, 2017 Report Share Posted June 2, 2017 Hi Juandiaza; Hardware setup -- Have you set the High Speed Inputs up for A-B encoder? Jumpers- Internal -- Is the Encoder PNP or NPN Output? Default is PNP, If NPN - Open unit, change JP12 to A( NPN) See the installation guide. Note: If Encoder is NPN, then JP12 set to NPN will cause ALL Inputs to be NPN If encoder is NPN, - Open Collector or Pull Up Resistors Internal? HMI Numeric Value tied to the MI you selected in Hardware setup. Dan Quote Link to comment Share on other sites More sharing options...
Juandiaza Posted June 5, 2017 Author Report Share Posted June 5, 2017 Hey Dan. I already change the default setting and did what you said and It's working. Thank you soo much Quote Link to comment Share on other sites More sharing options...
