MartinIT Posted June 13, 2017 Report Share Posted June 13, 2017 Hello , my guestion is: Can I use Unistream for controling two steppers motors like in Visio 430-J-TR34(PTO)? We manufactured one machine with this Visio systém. I used predefined bloks and it was OK. Is something like PTO in Unisteam? Is sample for direct controling two steppers morors? Thanks Martin 1 Quote Link to comment Share on other sites More sharing options...
Ofir Posted January 23, 2018 Report Share Posted January 23, 2018 Hello, I want to point that you can use the EXF-RC15 (Remote high speed IO ) on order to use PTO. The EXF-RC15 will be connected by CANBUS to the UniStream. The EXF-RC15 can be programmed in VisiLogic. Attached is an example. UniStream_070_exf-rc15_PTO_plus_jogging_two_channels new.ulprEXF-RC15 PTO plus jogging two channel for UniLogic examples.vlp Quote Link to comment Share on other sites More sharing options...
cbores1982 Posted June 6, 2018 Report Share Posted June 6, 2018 On 1/23/2018 at 3:44 AM, Ofir said: Hello, I want to point that you can use the EXF-RC15 (Remote high speed IO ) on order to use PTO. The EXF-RC15 will be connected by CANBUS to the UniStream. The EXF-RC15 can be programmed in VisiLogic. Attached is an example. UniStream_070_exf-rc15_PTO_plus_jogging_two_channels new.ulprEXF-RC15 PTO plus jogging two channel for UniLogic examples.vlp Ofir, I'm looking an example for V350 with EXF-RC15 two motors do you have one, that you can Share? I have an advance but only one motor I can make it work the Y, I have an issue with the communication.. the second is 2Y 1.0 Table X, Z, Y, Y UNICAN.vlp 1.0 V350_PTO_and_Jogging_For_EXF-RC15.vlp Quote Link to comment Share on other sites More sharing options...
meiyoukong2 Posted December 30, 2019 Report Share Posted December 30, 2019 have you solved the problem? Quote Link to comment Share on other sites More sharing options...
