viscoelastic Posted June 13, 2017 Report Share Posted June 13, 2017 I have an intermittent issue with download. It tells me the file is identical, when it's not. Even if I an an entire new rung it sometimes gives me the error. The only way I can get past it is by slightly moving an image on the HMI screen than it will download. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted June 13, 2017 MVP 2023 Report Share Posted June 13, 2017 This is rare, but I've seen it happen, too. I do what you do - change something else inconsequential. The other alternative is to select Download All & Burn, but that is rather lengthy. I know Unitronics is aware of this as it was mentioned by the instructor in a training course some years ago. Quote Link to comment Share on other sites More sharing options...
viscoelastic Posted June 13, 2017 Author Report Share Posted June 13, 2017 Thanks Flex Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted June 13, 2017 MVP 2023 Report Share Posted June 13, 2017 Are you doing a compile and save after the slight mods, before doing the download? If so, and without luck, perhaps a minor rename of the file will work as well. I have never encountered this issue, but I always do my first suggestion for the most minor changes. cheers, Aus Quote Link to comment Share on other sites More sharing options...
viscoelastic Posted June 20, 2017 Author Report Share Posted June 20, 2017 Hi Ausman, I tried what you said. It is intermittent. The only way I can get past it is by moving an object on the GUI slightly they it works. Quote Link to comment Share on other sites More sharing options...
