Anoop Rajan Posted June 17, 2017 Report Share Posted June 17, 2017 Hello, I have to configure a Vision 700 . The software was successfully installed. Is it possible to change the contrast and brightness of the display. It would be great, if anybody can help me in changing the contrast and brightness, I was not able to find anything about that point. Thanks in advance Regards Anoop Quote Link to comment Share on other sites More sharing options...
Ofir Posted June 17, 2017 Report Share Posted June 17, 2017 Hi, You can change the backlight intensity using system integer 9. The values is between 0 -100. 0 - off 100 - full 1 Quote Link to comment Share on other sites More sharing options...
Anoop Rajan Posted June 17, 2017 Author Report Share Posted June 17, 2017 Hi Ofir, Thanks for your answer. It is my first time, am using unitronix PLC and configuring one too. Thank you. Quote Link to comment Share on other sites More sharing options...
jedft123 Posted September 20, 2017 Report Share Posted September 20, 2017 I am using a V1210 and have the same question. Is setting the brightness via SI 9 the only way? Is there not a built-in screen config page with these types of settings? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 20, 2017 MVP 2023 Report Share Posted September 20, 2017 1 hour ago, jedft123 said: Is there not a built-in screen config page with these types of settings? No, there's not, but you can adjust SI9 directly through INFO Mode and it will retain that setting unless the PLC is initialized or the battery fails. Quote Link to comment Share on other sites More sharing options...
Kikis Posted September 27, 2017 Report Share Posted September 27, 2017 I use the following logic to achieve a screen sleep function for backlight's life economy. If MB26 is enabled by a toggle button on the screen, screen sleep function is on. If the screen has not been touched for a preset amount of time, the value of SI9 is set to zero and backlight turns off. When the screen is touched, backlight turns on. Quote Link to comment Share on other sites More sharing options...
Edison Posted August 19, 2021 Report Share Posted August 19, 2021 Good afternoon, thanks for the answers !! Quote Link to comment Share on other sites More sharing options...
