Sign in to follow this
Joel
OPC Problems with UniOPC to Ignition
I'm trying to get UniOPC to communicate with Inductive Automation's Ignition product, but cannot get Ignition to connect to the UniOPC server.  It recognizes the server (both application on same Win 10 PC), but will not connect.  Has anyone else done this with good results?  If so, any hints about any special configuration settings?  Note that UniOPC communicates just fine with OPC Expert, which is an OPC client application used mainly for troubleshooting.  Thanks in advance!
