Modbus TCP/IP Slave Configuration
Hello,
       I am need help with my application,
The controller is USP-104-B10 in may application i am using the Modbus TCP/IP to connect PLC with Scada System... in the computer i am using a software Modbus/OPC when i inserte the fists 255 register everything is ok but more than that i cant read any register
Somebody can help me?
  • MVP 2023
Do I understand you correctly that you are trying to read 255 registers at once via MODBUS? I believe there is a limit to how many registers you can read with a single Read Holding Registers command (a MODBUS limit, not Unitronics). Try breaking it up into multiple reads.
  • 2 weeks later...
