Ram Lavi Posted June 23, 2017 Report Share Posted June 23, 2017 Hi, I am using samba PLC and giving te user the option to enter a time to MB 20. I would like that automatically MB 21 will be set to one minute later. the problem is with times that ends with 9. 10:09 turns to 10:0A. how can I solve this issue? thanks, Ram Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted June 24, 2017 MVP 2023 Report Share Posted June 24, 2017 Hi Ram, Please post your code if you can, MBs do not directly relate to time. Are you wanting to change the RTC, or change a timer's setting? cheers, Aus Quote Link to comment Share on other sites More sharing options...
