Jamie123 Posted July 3, 2017 Report Share Posted July 3, 2017 Hello, I have two machines in operation that use Samba's. Both machines are identical. I have been having continued reports that the buttons on one of the machines fails to register on a regular basis, there have been no issues with the other machine. The screen has two large buttons on it. Every time I have been call out to fix this, the buttons work fine for me, the technician says the problem is intermittent and they have had no issues with the other machine. Is there a way to alter the screen sensitivity? How robust are these screens? Thanks in advance Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 3, 2017 MVP 2023 Report Share Posted July 3, 2017 Did you perform the screen calibration from Info Mode? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 3, 2017 MVP 2023 Report Share Posted July 3, 2017 Another possibility - these screens can only register a single touch at once. We're all used to multi-touch screens on our phones and these screens won't do that. If there is anything else touching the screen, the second touch won't register. Make sure the screen is clean and if the plastic screen protector is still on the screen, remove it. Confirm the operator isn't inadvertently touching the screen elsewhere when trying to push the button. Quote Link to comment Share on other sites More sharing options...
Jamie123 Posted July 3, 2017 Author Report Share Posted July 3, 2017 Yes I carried out a calibration, that's the only thing I could think of doing. Only one button would be pressed at a time. They are convinced the screen is faulty, but it works fine when I test it. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 3, 2017 MVP 2023 Report Share Posted July 3, 2017 7 minutes ago, Flex727 said: Make sure the screen is clean and if the plastic screen protector is still on the screen, remove it. Confirm the operator isn't inadvertently touching the screen elsewhere when trying to push the button. You didn't respond to this. Quote Link to comment Share on other sites More sharing options...
Jamie123 Posted July 3, 2017 Author Report Share Posted July 3, 2017 The screen protectors are still on both machines. I will remove them tomorrow. From watching the operator he only has one finger touch the screen. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 3, 2017 MVP 2023 Report Share Posted July 3, 2017 I've seen a particle of dirt get under the screen protector and cause intermittent fail. I've also seen the touch property of the screen fail completely, but it's rare. Quote Link to comment Share on other sites More sharing options...
Cam Posted July 4, 2017 Report Share Posted July 4, 2017 By any chance are the operators wearing a glove made of cloth material? 1 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 5, 2017 MVP 2023 Report Share Posted July 5, 2017 I could be wrong, but I believe these screens use resistive touch, not capacitance touch like phone screens. With resistive touch it's okay for the finger to be insulated. I often use a pencil eraser on my development PLCs to keep them pristine. Quote Link to comment Share on other sites More sharing options...
Jamie123 Posted July 6, 2017 Author Report Share Posted July 6, 2017 I have done something quite sneaky. I have been unable to replicate the fault, the button works for me every time, I suspect the operator has a bad aim. I have swapped the plc's without telling them. Will be interesting to see if the fault is then reported on the other machine. 1 Quote Link to comment Share on other sites More sharing options...
Isakovic Posted July 6, 2017 Report Share Posted July 6, 2017 I like your style. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 7, 2017 MVP 2023 Report Share Posted July 7, 2017 On 7/6/2017 at 7:18 AM, Jamie123 said: I have done something quite sneaky. I have been unable to replicate the fault, the button works for me every time, I suspect the operator has a bad aim. I have swapped the plc's without telling them. Will be interesting to see if the fault is then reported on the other machine. This is smart! Please report back with the results - we must know! Quote Link to comment Share on other sites More sharing options...
Jamie123 Posted July 10, 2017 Author Report Share Posted July 10, 2017 My sneakiness paid off. The operator likes to wear gloves 2 sizes too big to stop his hands sweating. You should have seen his face when I said I switched the PLC's. PS. he wasn't wearing baggy gloves when I was there.. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 10, 2017 MVP 2023 Report Share Posted July 10, 2017 Looks like it was @Cam who was on the right track. Quote Link to comment Share on other sites More sharing options...
Cam Posted July 10, 2017 Report Share Posted July 10, 2017 Good to know it's solved. Thanks for the update. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted July 10, 2017 MVP 2023 Report Share Posted July 10, 2017 Good out-of-the-box thinking! I can't tell you how many times an end user has managed to screw up my "perfect" creation. The worst offender was one who used his handy box cutter to press buttons on the touch screen. Joe T. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 11, 2017 MVP 2023 Report Share Posted July 11, 2017 14 hours ago, Joe Tauser said: The worst offender was one who used his handy box cutter to press buttons on the touch screen. Yeah, that and ball point pens. Ugh! Quote Link to comment Share on other sites More sharing options...
