Andreas Posted July 26, 2017 Report Share Posted July 26, 2017 Hi. I have found a problem with the 10" UniStream panel. If you set in an element in the corner, it will not work. I have tried this with 5 more displays, so this is not an coincidence. When will this be fixed? Quote Link to comment Share on other sites More sharing options...
DanT Posted July 27, 2017 Report Share Posted July 27, 2017 Hi; The Upper Right corner can take a Non Touch Image. The UniStream uses the Touch function in this corner to be able to get to the built in background functions of the UniStream Controller( like the 'I' Key on the Vision and M91 Series) When you touch this area, a menu will appear - UniApps -- the background system functions for Troubleshooting, Manual Communications setup, Upgrades, etc. Another feature is to take a Screen Shot of the current active user screen. Dan Quote Link to comment Share on other sites More sharing options...
Andreas Posted July 27, 2017 Author Report Share Posted July 27, 2017 Hi Dan. This i know, But then it should be informed that this corner cannot be used to have buttons and other touch elements in it. We had a problem with this when we sent a project with an button in this coner, I have now tested this on the 7" display too, and the same problem. Thanks. Quote Link to comment Share on other sites More sharing options...
