Samba 4.3" with modbus RTU communication
Hello,
For a project im working on I need to motitor serval energy sources and control multiple relays. I would like to use the Samba 4.3" PLC for giving a nice interface to the system. The problem is that I have over 30 outpust I need to control.
I've found a modbus RTU  (RS485) energy meter who measures the voltage and current. Also found a modbus RTU (RS485) digital output module with 16 outputs.
Is it possible to use the Samba 4.3" PLC with V100-17-RS4 module to communicate over modbus with the IO modules and energy meters?
Best Regards, Jelmer
