a062549 Posted August 29, 2017 Report Share Posted August 29, 2017 When I try to open my Visilogic I'm getting the following issue: Help? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 29, 2017 MVP 2023 Report Share Posted August 29, 2017 A little more information would be very helpful. Is this the first time to open VisiLogic after a new install, or has it been working fine and this started suddenly? What operating system are you running on your computer? Do you have other versions of VisiLogic installed? Did you install VisiLogic with UAC off and Administrator privileges? Are you running VisiLogic with Administrator privileges? Have you tried opening a different project? Have you tried re-booting your computer? If all else fails, uninstall VisiLogic and re-install, or else try installing the newest version (9.8.64) and using Version Swapper to swap to it and try that. Quote Link to comment Share on other sites More sharing options...
a062549 Posted August 30, 2017 Author Report Share Posted August 30, 2017 Here's the details: Just started it yesterday after a restart. Windows 7 Pro 64 bit No other versions installed Not trying to open a project at all, just wanting to look Rebooted several times I am the Administrator Don't really want to uninstall Thanks! John Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 30, 2017 MVP 2023 Report Share Posted August 30, 2017 22 minutes ago, a062549 said: 6. I am the Administrator Being the administrator is not sufficient. You must install VisiLogic "As Administrator" and run VisiLogic "As Administrator". The latest version of VisiLogic (9.8.64) does this automatically. Try uninstalling 9.8.31 and re-installing 9.8.64. Quote Link to comment Share on other sites More sharing options...
