Wai Spark Posted September 6, 2017 Report Share Posted September 6, 2017 I can not get U90 to install, It used to work on the computer but now after upgrading to windows 10 pro it doesn't want to work . I have uninstalled it and re installed it a few time now, downloaded the new version as well. it keeps trying to install solid Edge St8 and then freeze's or try's to install it to F Drive (usb hub) if connected, which doesn't have enough space to install it to then freeze's Any ideas? cheers u90 ladder issue.docx Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted September 6, 2017 MVP 2023 Report Share Posted September 6, 2017 I don't know if this will work, but try a complete uninstall of U90 similar to the Visilogic procedure: 1. Backup your projects 2. Uninstall U90 3. Delete directory C:\Program Files (x86)\Unitronics\Unitronics U90 Ladder 4. Delete directory C:\Program Files (x86)\Common Files\Unitronics 5. Reboot 6. Install U90 Let us know if this works. Joe T. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 7, 2017 MVP 2023 Report Share Posted September 7, 2017 Also, install "AS ADMINISTRATOR"! Quote Link to comment Share on other sites More sharing options...
