Saludos,
Soy novato,  quisiera saber por que  el bit de disparo de una alarma se activa solamente 1 vez, al reconocerla o quitarse la alarma y volverla a presentar el bit de disparo no se activa. Por otro lado muchas veces despues de reconcoer todas las alarmas activas me es imposible visualizar el display de alarmas. algunas veses se muestra y otras no.591f0b6e0d47a_problemaActivacion.png.68198ad5395e6b7949063b62dfa9d91a.pngPrograma1
33 minutes ago, EdwinCorrecha said:
Saludos,
Translated:
Regards,
I am newbie, I would like to know why the trigger bit of an alarm is only activated 1 time, when recognizing it or removing the alarm and resubmit the trigger bit is not activated. On the other hand many times after reconfirming all active alarms it is impossible to display the alarm display. some times it is shown and others are not.
I tested a simple alarm based on your post and the Active bit is tracking the alarm.  Post your code so we can see the rest of the Alarm configuration and your ladder logic.
