How to reset "Store direct"
Hi,
I made simple program to control analog outuput +/- 10V by display.
A have two buttons 1 and 2. And if I press button 1 a get analog output +0...10V and if I press button 2 then I get 0 ... -10V (what I set before on display).
Now I have problem if i press button I get setted output but when I release it I still have it.
Now I need that when I hold the button 1 or 2 I get signal from analog output and when I release it, it has to be 0.
I used Store direct function. Is it possble to do that?
I dont need linearization for this project.
test_analog-out.U90
  • 1 month later...
Hi to all again.
I have one question about ladder program that attached me @Flex727.
I have only one button and two end switches. I have on hydraulic cylinder to move down manualy and up automaticaly.
When I hold button I need setted output from MI 0 to move cylinder to the end position.
And when cylinder activates end switch 1 then I need output from MI 2 to move cylinder automaticaly  in zero position.
And when he reaches zero position he activates end switch 2 and he stops.
Is it possible to do that?
I know how to do it with digital outputs Reset and Set, but with analog outputs no :unsure:
  • MVP 2023
Sounds like you need to program a small sequence, now that you've told us what you're trying to do.
Your button becomes a START button, which cycles the cylinder through it's movement.  I've attached an example.  I edited your I/O to have one button and two switches.
You don't have to hold the button while the cylinder is moving.  And you can't stop it mid-stroke  - I'll leave that as an exercise for you.
P.S. @Flex727 - You know I love my state machines.
test_analog-out_BL_JT.U90
Here is my test program that its not finished yet, because I need to add function that cylinder automaticaly moves back to Home Switch when I release button.
In my project I have proportional valve that needs +/-10V to drive it and I have 2 valves that has to work together.
1. When I press and hold Button_1 first it has to activate Valve_1 and after some time (timer T0) it has to activate Valve_2 and proportional valve on speed MI 0.
(Cylinder is moveing when proportional valve is acivated).
1.1 This is written in the program in Part 1 and its working.
2. When cylider activates End Switch it has to move back automaticaly until he activates Home Switch:
-  Button_1 is not pressed
- Valve_1 is activated
- Delay activated Valve_2 and Proportional valve on speed MI 2
2.1 This I have to add in the program Part 2 :/
test_analog-out_KIki.U90
