DanT Posted October 3, 2017 Report Share Posted October 3, 2017 HI; Customer has to Ethernet/IP into an OMRON Safety PLC. We have the EDS file (NX-EIC202), and can make the connection and get the Basic Parameters. The issue is setting up the T2O and O2T Assemblies and Structs for the Global Variables. ( we have done Ethernet/IP Setups for Bar Code Scanners and MURR IO Blocks sucesfully,) We cannot locate the relevent data in the Omron Information. Information, experiences would help. Dan Quote Link to comment Share on other sites More sharing options...
Pista Posted October 4, 2017 Report Share Posted October 4, 2017 Hi, In france but maybe it can help. https://www.youtube.com/watch?v=oP5RQ7BHx5M or this pdf. https://industrial.omron.mx/en/media/NX-EIC202_RA_PLC_QuickStart_en_201503_QSG-RA-PLC-NXEIC_tcm871-110543.pdf Quote Link to comment Share on other sites More sharing options...
Dave Posted October 28, 2017 Report Share Posted October 28, 2017 Hello All. The application Dan references above is using the Unistream as an Ethernet/IP master to an Omron NX-EIC202 Ethernet/IP Coupler, which has a Safety CPU and a number of safety I/O "slices" attached. Parameters ended up as follows: Input Assembly 100 Output Assembly 148 Configuration 199 Leave both Run Idle check boxes UN-Checked Leave Config Size empty Leave Multicast checkbox UN-Checked I don't really know much about EDS files and I got fooled by viewing the EDS file for the NX-EIC202 in notepad, and after seeing the following, used 150 instead of 148 for the output ass'y "Param2,Assem150, $ O->T RPI, size, format ,Param1,Assem100, $ T->O RPI, size, format" Hope this helps anybody/everybody escape the time consuming trial & error approach I went through. Quote Link to comment Share on other sites More sharing options...
