Jeroen Keetels Posted October 6, 2017 Report Share Posted October 6, 2017 I am working to set up an IOT network. We create devices for in workshops and we want to collect information from these devices. I want to send this information via a LoRa network. We use the Samba SM43-J-R20 and the USP-070-B10 and they should communicate with a LoRa module. Is it possible to set up a communication via the mini USB of both devices? We want to keep the hardware as cheap as possible and these connections are present on both models. Quote Link to comment Share on other sites More sharing options...
DanT Posted October 6, 2017 Report Share Posted October 6, 2017 The USB ports on the Unitronics PLC's are for Programming Only. They are not available for communications with other devices. You will have to use the Serial Ports( installed, or added in) or an Ethernet Port ( already installed or optional Addon) Quote Link to comment Share on other sites More sharing options...
