Bujar Posted October 7, 2017 Report Share Posted October 7, 2017 I have a project where I have two encoders one absolute enkoder 750 and one incremental 200 which plc do i have to choose Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted October 8, 2017 MVP 2023 Report Share Posted October 8, 2017 What are the specific manufacturer and model numbers of your encoders? Joe T. Quote Link to comment Share on other sites More sharing options...
Bujar Posted October 8, 2017 Author Report Share Posted October 8, 2017 Hi It is an beending machine, Absolute encoder 670900020, res, 720 gray, volt 9-30 lein &linde and eltra El63D200S5/28P6X6MR. the same machine is in this link: http://www.argemaq.com/en/producto/automatic-stirrup-bender-coil-14-schnell/ thank you very much Quote Link to comment Share on other sites More sharing options...
Bujar Posted October 8, 2017 Author Report Share Posted October 8, 2017 I think V350-J-T38 but I'm not sure ??? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted October 9, 2017 MVP 2023 Report Share Posted October 9, 2017 I couldn't find an exact data sheet on the 670900020, but if it's gray code you'll need one input per bit and decode it in your logic. What is the output voltage level? What is the output resolution (number of bits)? The Eltra looks like it can be powered from 24V and can connect directly to the high speed input of the V350 (I0 and I1). The -T38 is probably a good choice depending on how many inputs you'll need for the absolute encoder. Joe T. Quote Link to comment Share on other sites More sharing options...
