Swervomotor Posted October 11, 2017 Report Share Posted October 11, 2017 Good day, Is it possible to reference a string tag for which file to view in the PDF Viewer? We have thousands of PDF's I will FTP the current PDF part drawing to the SD card and delete the last PDF part drawing. I believe I can just use a Rename File and overwrite a "sacrificial" PDF file name then reference that for the PDF viewer but wanted to know if their was a better way. Thanks. -Swervomotor Quote Link to comment Share on other sites More sharing options...
NoamM Posted January 23, 2018 Report Share Posted January 23, 2018 Hi Swervomotor, Currently its not possible to use a tag for the file name. I will add your feature request to Unitronics R&D. thanks. Quote Link to comment Share on other sites More sharing options...
