Enrique Posted October 25, 2017 Report Share Posted October 25, 2017 HI every one. I'm trying to develop a web page using bootstrap framework but it seems like the web server does not support it, even if I store all the css in a different file, it does not work!. Do you know if this is possible? Quote Link to comment Share on other sites More sharing options...
DanT Posted October 25, 2017 Report Share Posted October 25, 2017 Hi Enrique; The Vision Series Web Server feature is VERY Basic. Text ONLY, You can create pages for text, display variables, modify variables, display strings, and enter strings. Not much , but useful for basic what is happening here and simple set point changes from afar. If you want to have a full featured Web Server in your PLC, go to the UniStream Line. Check out the UniStream Videos on the Webserver on YouTube. 1 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted October 25, 2017 MVP 2023 Report Share Posted October 25, 2017 I've never done it, but I thought you could run a full-blown webserver off the SD card in the Vision line. No question though that UniStream is more powerful in that regard. 1 1 Quote Link to comment Share on other sites More sharing options...
DanT Posted October 26, 2017 Report Share Posted October 26, 2017 There is an application for a more graphical Webserver based on the V350 Series. and uses a SD Card. This is a locked set of subroutines written by a programmer years ago. They cannot be exported, so you have to use that as the starting point and change the PLC model, and built your own control logic on top of it. Look under Technical Support-Tools and Applications-Complex WebServer Just be prepared to scratch your head a lot. There is not a lot of support information about it beyond what is provided in the zip file, and old forum posts. Dan 1 Quote Link to comment Share on other sites More sharing options...
