msnsaradha Posted October 25, 2017 Report Share Posted October 25, 2017 Based one some guide line, i can send and receive the text from PC -PLC through RS232 HYPER TERMINAL. Now, i have a GPS data Text File, that has bulk of text starting with $ and end with *XY (XY-Numbers). The lines are shown in the attached text file. In this bunch of lines in the text file i need only "$GPGLL" starting text message. For that i have used "$GPGLL" in Index of message and * in end of text in FB Scan. I have received the text message, only if "$GPGLL" present in the first starting line of the text file. If this $GPGLL is in second starting line, the PLC has failed to read "$GPGLL" text message. For that i hope FB scan need continuous or loop scanning for each line starting with $, I have tried with different attempt, but failed. Moreover, if the text file has more than one $GPGLL" starting text message, each text message should be display in HMI one by one. I have tried upto my knowledge but failed. Kindly Help me Sir. i need to scan multiple text lines at a time and choose a few text lines from that to display. I hope unitronic tech people may help to solve. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted October 25, 2017 MVP 2023 Report Share Posted October 25, 2017 Post your code. Joe T. Quote Link to comment Share on other sites More sharing options...
msnsaradha Posted October 25, 2017 Author Report Share Posted October 25, 2017 26 minutes ago, Joe Tauser said: Post your code. Joe T. I can't able to attach my files here. Kindly give your email address Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted October 27, 2017 MVP 2023 Report Share Posted October 27, 2017 joe@jtauser.com Quote Link to comment Share on other sites More sharing options...
