Paul R Posted October 29, 2017 Report Share Posted October 29, 2017 Hi all - I am new to Unitronics and need some assistance. I connected my PT100 probe to a Jazz controller and set it up on the hardware but do not know how to do the ladder programming and how to put it on the screen. The temp reading must be control by a set point. I look all over and can not get a proper example of the ladder programming only the HMI linear scale thing. can someone help me with an example . Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted October 29, 2017 MVP 2023 Report Share Posted October 29, 2017 HI Paul, pls have a look at the "Linearization of two inputs" example found either via Help, or directly via C:\Program Files\Unitronics\Unitronics U90 Ladder\Examples\Flow, totalizing and pump control. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Paul R Posted October 30, 2017 Author Report Share Posted October 30, 2017 Thank you Aus - got it now Paul Quote Link to comment Share on other sites More sharing options...
