PeterFukt Posted October 31, 2017 Report Share Posted October 31, 2017 Hello, I'm trying to figure out how to make a watchdog function in a Samba SM35-TA22- The customer will use TCP/IP to mostly read values from the PLC. If the communication goes down, the unit should stop. But I have no idea how to make this. I was looking at SB147 which is Socket 0 connected but it is constantly changing when I disrupt the connection, I guess it is due to auto connect. Is it the best option to use SB147 with perhaps a timer so if it is on for 10 seconds, that means the communication is up and the unit can run, but if sb147 change, the timer reset and the unit is stopped. I just want some feedback if I'm all wrong here. Thanks! //Peter Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted October 31, 2017 MVP 2023 Report Share Posted October 31, 2017 Usually you set up a heartbeat bit. SB 147 does not guarantee that the Master was successful. The Master does a write and sets a bit in the PLC after it does a read. The PLC sees this bit and notes that communication is OK. Then it turns it off. The heartbeat bit is also running a timer. If the timer times out you know there hasn't been communication in a while. Joe T. Quote Link to comment Share on other sites More sharing options...
PeterFukt Posted November 6, 2017 Author Report Share Posted November 6, 2017 Is there an example of this somewhere? I want the unit to run normally even if Modbus is not used at all. //Peter Quote Link to comment Share on other sites More sharing options...
hotwires Posted November 6, 2017 Report Share Posted November 6, 2017 Peter, I have implemented a fairly basic com fail detection scheme I used in serial MODBUS RTU's. As Joe T. stated this is a heartbeat the master sends to the slave (and also can be echoed back for loss detection at the master). Toggle bit each time the MODBUS master's R/W function is called, that bit is sent to slave (in write coil), branch PTC and NTC contacts (HB bit) to a TOF timer in the slave ladder. Each time the heartbeat bit changes states in slave, the timer OFF delay is kept from expiring. set TOF time base according to how many cycles you want to allow it to miss before expiring, Use an inverted contact linked to TOF.out, that can drive an MB coil that is your com failure signalling bit (which in turn can zeroize outputs or whatever you want to happen). I use SB2 branched in with PTC and NTC of heartbeat bit, this prevents the TOF from being expired at power up (depending on where the master is in the polling cycle the slave may not see an HB bit transition at the slaves POWER UP. Hope this helps. If it's still clear as mud I can try to dig up a redacted code example for you. Hotwires Quote Link to comment Share on other sites More sharing options...
PeterFukt Posted November 7, 2017 Author Report Share Posted November 7, 2017 Thanks Joe and Hotwires, I think I might figure it out. Some code would have been very helpful. To much to do but no time for extra thinking at the moment. Quote Link to comment Share on other sites More sharing options...
hotwires Posted November 8, 2017 Report Share Posted November 8, 2017 The toggle bits change at the end of each polling cycle and transport via serial MODBUS to toggle O9 in the slave (an MB could also be used), PTC/NTC contacts keeps TE3 alive, O9 loops back to an input on the slave the is read by the master (call it a hairpin or loopback), the same scheme is used again in the master to monitor the echo of the toggle bits. it's fairly fool proof. If the toggle bit gets stuck in either state for longer than the timers preset then a bit will go true on both the master and the slave. Quote Link to comment Share on other sites More sharing options...
PeterFukt Posted November 28, 2017 Author Report Share Posted November 28, 2017 Thanks for the help. I think I got it to work finally. Quote Link to comment Share on other sites More sharing options...
