Guest PEDRO Posted November 3, 2017 Report Share Posted November 3, 2017 Hi guys, I am new and I am programming 4 load cells with a V430 j t2, I have an error in the loadcell block CONF: LC command = 3 LC succes bits = 0 LC Funtion in progress = 0 LC command = 3 = The I / O expansion module linked to the configuration is busy but the I / O are not busy ... how can I solve this problem? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted November 8, 2017 MVP 2023 Report Share Posted November 8, 2017 Need to see the rest of the loadcell config and how your hardware is laid out. Please post your code. Joe T. Quote Link to comment Share on other sites More sharing options...
