MalSnaize Posted November 9, 2018 Author Report Share Posted November 9, 2018 HI all As I had already ordered a replacement unit I thought I'd wait for that to arrive before following up with support team. It seems that in one hit I've resolved both the date/time reset issue and the other thread on peripeheral devices not registering. I simply unboxed the new V1210, (did a quick date/time on power cycle test) then loaded my software and it ran first time. Power cycle doesnt touch the clock! All sorted - thatnks for all of your input folks regards Mal Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted November 9, 2018 MVP 2023 Report Share Posted November 9, 2018 Great!... But a very frustrating path! cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted November 10, 2018 MVP 2023 Report Share Posted November 10, 2018 Good news - the solution is found.For the future I advise you to make a detailed description of all the actions done on this object. Make a photo of the nameplate. And even if it's possible (no warranty limitations) to make high-quality photo boards inside the device (new and old defective), as well as photo ( screenshot ) versions of programs and firmware versions.Let's hope that the problems will not be repeated.I always document such cases (my favorite way - to write or print on paper?). It is very helpful in the future. cheers, kratmel Quote Link to comment Share on other sites More sharing options...
MalSnaize Posted November 10, 2018 Author Report Share Posted November 10, 2018 Yes good news indeed! Thanks for your advice and guidance Kartmel and for your support and ideas throughout the resolution process. Kind regards Mal Quote Link to comment Share on other sites More sharing options...
GetAGripOnIt Posted June 4, 2020 Report Share Posted June 4, 2020 I have a V350 with a very similar problem. The clock is resetting to 1/1/2006 on power up even when the MI's are not being lost. This PLC did loose its program due to a power loss/surge even though the battery was fine. Then I reloaded it with a new program and it is fine except for the clock resting issue. Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted June 4, 2020 MVP 2023 Report Share Posted June 4, 2020 Please share model or nameplate photo. Is it problem present from start with V350 or it appears on long time normal working installation? Quote Link to comment Share on other sites More sharing options...
