Interroga Posted November 17, 2017 Report Share Posted November 17, 2017 Hi guys . I need help for understand configuration types in inputs A and B for visiologic in PLC/IHM Samba. I hope you can help me. best regards, Mauro. Quote Link to comment Share on other sites More sharing options...
viscoelastic Posted November 17, 2017 Report Share Posted November 17, 2017 Do you mean the types in the I/O config or you need help with the ladder? Quote Link to comment Share on other sites More sharing options...
DanT Posted November 17, 2017 Report Share Posted November 17, 2017 Hi; What type of encoder are you planning to use? Single Channel - pulse train counting up in any direction? Internal or external reset? A-B Quadrature Count Forward or Backward? With marker pulse? The High Speed Inputs are configured in the Hardware setup , select the method, assign an MI(16 bit +/-) or an ML (32bit +/-) If encoder inputs are NPN, then set the Jumper( internal) for NPN - ALL Inputs will be NPN Check Example Programs - Help-Examples for programming Quote Link to comment Share on other sites More sharing options...
Interroga Posted November 26, 2017 Author Report Share Posted November 26, 2017 Thanks for your help. My problem was in encoder , where one out (B) not worked. I create animation with inputs for testing. because that's how I saw my problem. Thank you very much for all. Regards. Quote Link to comment Share on other sites More sharing options...
