kokhua Posted November 22, 2017 Report Share Posted November 22, 2017 Hi, I 'm trying to interface an USB bar-code scanner (HandHeld IT3800, model 3800LTP-12) with my UniStream (model: USP-104-B10). I configured the Panel USB Port as below: and created the following rung to capture the data read by the barcode scanner: However, when I plugged the bar-code scanner into USB Host Port 1 of the UniStream, the bar-code scanner was detected as keyboard instead. Nevertheless, I clicked "Reset Display" to continue, hoping that the bar-code scanner can still work, I then scanned a sample bar-code but nothing was captured. Any idea on how to get this to work? Thanks KokHua Quote Link to comment Share on other sites More sharing options...
sergiog860 Posted November 22, 2017 Report Share Posted November 22, 2017 Hi, What values do you have in "barcode1Length" and "barcode1Status"? Quote Link to comment Share on other sites More sharing options...
kokhua Posted November 28, 2017 Author Report Share Posted November 28, 2017 Hi, sergio Both the "barcode1Length" and "barcode1Status" read value 0. When I plugged the USB bar-code scanner into one of the USB ports of my PC, it works well. From the Device Manager, I found out that it is detected as USB Input Device (under the category of Human Interface Devices). So, I guess this is why it is detected as keyboard. And, with the Panel USB Port configured as "Tx/Rx, 115200, 8, None, 1, 50", it certainly won't work with the Panel USB Port setting. kokhua Quote Link to comment Share on other sites More sharing options...
cbores1982 Posted January 10, 2018 Report Share Posted January 10, 2018 I try to do the same Barcode Scanner HR-100Serires Keyence to UniStream® 7" USB port. I Use the tutorial Message Composer.. I do not receive any information. Quote Link to comment Share on other sites More sharing options...
Interroga Posted January 23, 2019 Report Share Posted January 23, 2019 i have same problem with code reader usb sg20 - intermec. D'ont work in USB input usp-104-b10. I read all topics inside this forum and not found anwser. This model is defaul merck laboratories, company where give support in pharmaceutics systems. I need help for this case too. regards. Quote Link to comment Share on other sites More sharing options...
