Interroga Posted November 26, 2017 Report Share Posted November 26, 2017 I wold like know how to declare for function in the input values for preset timer inside the UDFB? best regards. Quote Link to comment Share on other sites More sharing options...
Dave Posted December 1, 2017 Report Share Posted December 1, 2017 not sure why, but you can't use timers in UDFB's. Maybe you could increment a variable within the UDFB using, for example, the frequency.frequency 1 (s) as a trigger, then comparing the variable as required? Quote Link to comment Share on other sites More sharing options...
Interroga Posted December 3, 2017 Author Report Share Posted December 3, 2017 I declare external timer on logic. I will go testing . If working ok, i publish this results. Regars, mauro Quote Link to comment Share on other sites More sharing options...
curtharrington1 Posted November 18, 2020 Report Share Posted November 18, 2020 A timer is a basic struct. UniLogic doesn't support nesting one struct inside of another. Quote Link to comment Share on other sites More sharing options...
