Martin Sirovy Posted December 8, 2017 Report Share Posted December 8, 2017 Hello, I have Unistream 7 and I have problem with configuration of high-speed output of module UIS-WCB2. The high speed output 0O should be able to be configured up to 250 kHz using PWM mode. According to help, I have configured in properties windows HS Block 1 to PWM - see screenshot. Then I have configured the struct B1 according to the screenshot, but it still does not work. The classical "slow" output using function PWM worked, however I can not get to work the high-speed 100 Khz+ output mode. Thank you very much for any tips. Best regards, Martin Sirovy. Quote Link to comment Share on other sites More sharing options...
Martin Sirovy Posted December 14, 2017 Author Report Share Posted December 14, 2017 The problem is solved - I did not noticed, that the minimal frequency in HSO mode is 6 Hz. Thank to the support for a fast response. Quote Link to comment Share on other sites More sharing options...
Skof Posted June 5, 2020 Report Share Posted June 5, 2020 Hi Martin, I am just getting to know how PWM works on Unistream. I too have UIS-WCB2 module and having trouble configure the PWM HSO. Did you set up a target value (for number of pulses sent), somehow in your project? How did you manage to work it out? Did you use a custom made function ? Tnx, BR Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted June 5, 2020 MVP 2023 Report Share Posted June 5, 2020 This post is a little old. You're probably not going to get a reply from Martin. PWM is not a discrete pulse output type, so there is no "number of pulses"sent out. That is a"pulse" output. Are you looking for pulses out to control a stepper or a continuous PWM output to drive an SSR? The -WCB2 does PWM. Enable it under HS Block in the Properties window of the module- Once you do that, PWM values magically appears in the IO Struct- Let us know more specifically what you are trying to do. Posting your program is also a really good idea. Joe T. Quote Link to comment Share on other sites More sharing options...
