C_R_PLC Posted December 12, 2017 Report Share Posted December 12, 2017 So I'm currently in the process of adapting an old program to fit our current needs for my work, but after adding things to it it's giving me an error saying there are 18 fonts when only 15 are allowed. I've manually gone through and counted and there are only 3 that I can see, but I'm at a loss as to how to go from here. Is there any quick fix to this or am I going to have to redo the HMI completely? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 12, 2017 MVP 2023 Report Share Posted December 12, 2017 Strange. The project I'm working on right now has 24 fonts installed, of which 17 are in use. It compiles with zero errors. What PLC and VisiLogic version are you using? Quote Link to comment Share on other sites More sharing options...
C_R_PLC Posted December 13, 2017 Author Report Share Posted December 13, 2017 V350 and Visilogic 9.8.65 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 13, 2017 MVP 2023 Report Share Posted December 13, 2017 My suggestion is to download a blank project, then re-download the project giving you problems. Also, make sure the firmware on the PLC is up to date. Also, in the Fonts Handler in VisiLogic, press the "Delete All Unused" button to make sure you've cleared out everything. Quote Link to comment Share on other sites More sharing options...
