solomoneli Posted December 13, 2017 Report Share Posted December 13, 2017 Footsprayer v1.0.U90 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 13, 2017 MVP 2023 Report Share Posted December 13, 2017 You've got the right idea here, just move the T2 contact and O2 Reset to the next ladder rung. Also, don't create multiple networks in the same ladder rung. Quote Link to comment Share on other sites More sharing options...
solomoneli Posted December 13, 2017 Author Report Share Posted December 13, 2017 I will clean it up, thanks for the help. What function would I use to get O1 to start again without triggering the input, thereby starting the whole routine again? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 13, 2017 MVP 2023 Report Share Posted December 13, 2017 I see that you've placed the contact for the Timer on the same network as the coil many times in your program. Don't do that. Break it up as I showed you above. Not sure what you're asking about O1 starting again. It will start whenever you get a pulse from the Pressure Mat. Quote Link to comment Share on other sites More sharing options...
solomoneli Posted December 13, 2017 Author Report Share Posted December 13, 2017 I'm running a test cycle for the program, and I want the whole thing to cycle through endlessly without having to trigger the Pressure mat. So once the pressure relief valve closes, it would start the cycle again, Ideally it would start again in between the pressure mat and the O1. Would I make the reset of the pressure relief valve trigger MB1? I will clean up the program and try that and respond if I can't get it to work. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 13, 2017 MVP 2023 Report Share Posted December 13, 2017 Yes, that would work. Quote Link to comment Share on other sites More sharing options...
