drr Posted December 15, 2017 Report Share Posted December 15, 2017 I'm developing a recipes application in a sm43-j-r22. I want to disable or turn off the display if no control is touched in 5 five minutes in order to improve de durability of te device. Thescreen must be turn on if the user touch the screen again. Is this possible? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 15, 2017 MVP 2023 Report Share Posted December 15, 2017 Yes, use SI 9 to adjust the backlight intensity from 0% - 100% and use SB 16 to return the screen backlight to its previous value. Be careful though, when a user touches a dark screen, any button or control that is there will be activated. I usually load a blank screen when I dim the display to prevent inadvertent activation of some control. Quote Link to comment Share on other sites More sharing options...
drr Posted December 16, 2017 Author Report Share Posted December 16, 2017 Ok, it's a good idea. Quote Link to comment Share on other sites More sharing options...
