sgull Posted March 15, 2011 Report Share Posted March 15, 2011 Hi all Starting a project soon and need to know if it is possible to use a vision 570 as a master to a non-unitronics PLC. All documents and topics appear to indicate that the unitronics must be set to slave. Also if i have 2 non-unitronics PLC's, do i need a ethernet hub to connect with the 570. Hope you can help. Regards Denis Quote Link to comment Share on other sites More sharing options...
Ofir Posted March 15, 2011 Report Share Posted March 15, 2011 Hi Denis, You can use Unitronics controllers either as MODBUS master or MODBUS slave. If you are going to use MODBUS IP then of course the V570 must comprise Ethernet port. Then as in any Ethernet network if you wish to connect more than 2 device then you need to use hub or a switch.. Quote Link to comment Share on other sites More sharing options...
sgull Posted March 17, 2011 Author Report Share Posted March 17, 2011 Thanks Ofir Will give it a try and hopefully will get it to work. Quote Link to comment Share on other sites More sharing options...
